Contributor I
Are onboarded users require to reonboard?
Hi all,
My superior is planning to change the management IP of ClearPass.
Thus as per title above, are current onboarded users require to re-onboard after we changed the management IP of Clearpass?
Thanks.
Re: Are onboarded users require to reonboard?
EAP-TLS is based on a certificate, no an ip address...  If you are doing OCSP to check revocation you might need to make sure that your OCSP settings are looking at the right ip address/hostname to check revocation
It should not, but you should consult your Aruba Partner to take a look at
your config to be sure.
Tim Cappalli | Aruba Security
