Aruba 3200 manual blacklist/block
We have a Aruba 3200 controller. What i would like to do is block/ban/blacklist a devide (prob by MAC address) if i feel it is acting inappropriately. I know i can search for the device and select to blacklist it, but if the device is not currently connected then i cannot find it on the client search and therefore cannot blacklist it.
Is there a way to manually add a MAC address so that device is blacklisted when it tries to connect? I have a list of MAC addresses id like to blacklist. Or is there a better way to blockban devices then above. I know i can do it at a firewall/UTM level but would prefer to do it at the Aruba WiFi level. Currently we are just using basic SSID with WPA security. No RADIUS, captive portal, etc.
Thanks in advance for your help.
Re: Aruba 3200 manual blacklist/block
You need to do it from the commandline.
Please see here:  http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-stm-add-blacklist-client/m-p/1048/highlight/true#M79
Thanks for the reply. I tried that and got the attached result unfortunately.
You need to be in "enable" mode to do this.  type "enable" and  then the enable password.
Great! Thanks for that.
I know this is an old thread but for those like me who do end up reading it:
The blacklist now stays through controller reboot huzzah!
Tested on 6.3.1.5
I can successfully block users from the CLI, but the problem is that i cant make them permanent blacklisted.
Ive set the Blacklist Time within the virtual APs that is affected to zero, but what ever I do when i use show ap blacklist-clients i get 3600 sec.
What am i doing wrong?
Johan
jokohanho,
Are you blacklisting a user that is currently connected, or no longer connected.  If the user is connected, it is the virtual AP that controls it.  If the user is NOT connected to the controller it corresponds to the "show ap blacklist-time" parameter:
To see how long a user is not connected would be blacklisted:
(192.168.1.3) #show ap blacklist-time
ap blacklist-time:3600
 To change the blacklist to permanent:
(192.168.1.3) #configure t
Enter Configuration commands, one per line. End with CNTL/Z
(192.168.1.3) (config) #ap ap-blacklist-time ?
<ap-blacklist-time>     time in seconds
(192.168.1.3) (config) #ap ap-blacklist-time 0
Sorry, i missed to mention im trying to block mac addresses. :)
The mac address is not connected at this point.
So how do I change the ap blacklist-time?
