Occasional Contributor I
Aruba 7010 inconsistent ping response from APs connected directly to the controller
I am in the process of installing a new 7010 controller and I cannot get consistent ping responses from any of the APs, one time I get no responce 0% and the next time i get 100%. They are connected directly to the controller and receive an IP from a DHCP on the network. I have added all of them to the whitelist but they do not show up in the AP wizard.
Re: Aruba 7010 inconsistent ping response from APs connected directly to the controller
type "show log system 50" and see if they are rebooting for some reason.
Also type "show ap database" to see if they have any flags.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
(HTI-Aruba7010) #show log system 50
May 21 21:19:42 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:19:43 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:19:43 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:19:43 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:19:58 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:19:58 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:19:58 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:20:02 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:20:02 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:20:13 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:20:13 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:20:13 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:20:22 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:20:22 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:20:28 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:20:28 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:20:28 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:20:42 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:20:42 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:20:43 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:20:43 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:20:43 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:20:58 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:20:58 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:20:58 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:21:02 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:21:02 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:21:13 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:21:13 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:21:13 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:21:21 :307048: <DBUG> |cfgm| Got a message from 8344:5005
May 21 21:21:21 :399814: <DBUG> |cfgm| replyGetLmsListRequest:307 Sending IP 192.168.214.2 to 8344
May 21 21:21:22 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:21:22 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:21:28 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:21:28 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:21:28 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:21:42 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:21:42 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:21:43 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:21:43 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:21:43 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:21:58 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:21:58 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:21:58 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
May 21 21:22:02 :307026: <DBUG> |cfgm| master: Refreshing the lms list
May 21 21:22:02 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 192.168.214.2 flag value is 1, missed HB 0 socketID -1
May 21 21:22:13 :307048: <DBUG> |cfgm| Got a message from 8231:5010
May 21 21:22:13 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
May 21 21:22:13 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
(HTI-Aruba7010) #show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
M = Mesh node; Y = Mesh Recovery
Total APs:0
