Contributor I
Aruba ClearPass guest portal with IAP - problem with login
Hi
We have a cluster of IAP-305 and ClearPass 6.7
We have a strange issue with configuring CPPM Guest as external portal for IAP and MAC-caching.
We have configured a new guest page with sponsorship and point this page as external captive portal in IAP configuration in Guest WLAN.
The guest portal appears correctly but when we try to login nothing happens (login page appears again) and there is no entries in Access Tracker or Event Viewer.
Public wiledcard certificates are correctly imported to CPPM.
There is no firewall between IAP clutser and CPPM.
When I test: aaa test-server, the result is successful
What can be other reason why the process of logging doesn't end with success ?
Any help will be much appreciated.
best regards
Karol
Frequent Contributor II
Re: Aruba ClearPass guest portal with IAP - problem with login
Have you imported the same wildcard cert to IAPs? If so, have you changed your registration page Login-> * IP Address from securelogin.arubanetworks.com to captiveportal-login.WILDCARDDOMAIN?
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Contributor I
Hi
Sorry for late delay and thank you for suggestion.
In meantime it has started to work. I don't know exactly what has helped.
We have had imported cert to IAP VC and set link in CPPM to
captiveportal-login.WILDCARDDOMAIN, so it wasn't a problem.
We have made some misc config like (set NAS IP, set NTP and enforce https request in CPPM) and it helped.
Anyhow thank You for your help
Karol
