Frequent Contributor II
Aruba Clearpass and Controller Guest redirection issue?
I Have configured Clearpass and Integrated it with Aruba Controller I have configurd all integration parameters and captive portal redirection is working well,but after the user entered his credentail it redirected to Securelogin URL and didnt go any where else so what may be casue of this problem?
Re: Aruba Clearpass and Controller Guest redirection issue?
Do you see a successful web auth in ClearPass?
Tim
Tim Cappalli | Aruba Security
Yes it show as accepted
Did the role change on the controller? What connectivity does the client have?
Tim
Yes he got the right role which I made it authenticated
So I’m not following what the issue is? Can the user pass traffic?
No user just after entering credentails he redirected to securelogin and not redirected to the internet
Trusted Contributor I
so you see a succesful web auth, but do you see a succesful radius request?
