Super Contributor II
Aruba Controller ArubaOS direct integration with PAN firewall
Hi All,
Just wondering if there is any planned direct integration between ArubaOS and PAN firewalls similar to what exists for the Instant APs? I.e. without ClearPass?
Scott
Re: Aruba Controller ArubaOS direct integration with PAN firewall
There is a Palo featureset built into 6.4. Check out chapter 28 in the 6.4 User Guide.
Tim Cappalli | Aruba Security
Moderator
As pointed out by Tim [thanks]...we built integration with PANOS in AOS in 6.4. This is based upon the PAN-OS UserID XML-API similar to what we initially released in our first CPPM integration.
Note: CPPM has recently added additional integration over and above UserID to include HIP Objects.
Best Regards
-d
ClearPass Product Manager
thanks all for your replies. looks like i've got some new testing to do!
We configured ... but are still getting DOWN... any ideas?????
(Aruba-local) #show pan state
Palo Alto Networks Servers Connection State[PA5050demo]
Firewall            State
###.##.###.###:443  DOWN[03/06/18 15:49:15]
Does the PA firwall need to have a trusted certificate for the controller?
Is that why PAN still shows in a DOWN state.
Firewall            State
