Frequent Contributor I
Aruba IAP RADIUS backhauled to CPPM; VLAN enforcement
Hi all,
I tried using a 'VLAN enforcement' template under Enforcement Profile.
But this is IETF based, and looks like this,
Type                        Name                                    Value
Radius:IETF            Session-Timeout                  10800
Radius:IETF            Termination-Action               RADIUS-Request (1)
Radius:IETF            Tunnel-Type                         VLAN (13)
Radius:IETF            Tunnel-Medium-Type           IEEE-802 (6)
Radius:IETF            Tunnel-Private-Group-Id      Enter VLAN --> I have purely entered the vlan id here
But I can't get it to work with an IAP/CPPM deployment.
The Radius type of 'Radius:Aruba', Attribute: 'Aruba-User-Vlan' works fine.
But id rather implement IETF type.... I'm going on the template offered by CPPM.. Should I be choosing other attributes ?
Re: Aruba IAP RADIUS backhauled to CPPM; VLAN enforcement
The Aruba-User-Vlan option is recommended with Aruba equipment.
Tim Cappalli | Aruba Security
Implying it will not literally work, period, with IETF Radius attributes ?
It should, but the Aruba VSA is one attribute vs 4+ for the IETF one.
