- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Aruba Insight Management Login
05-18-2017 11:33 PM
I'm struggeling with the Clearpass Insight Login. I've Build a Service which grant's Management Access to CPPM via Active Directory Backend with User-Role Super-Admin. Everything works fine and if a User is Logged into CPPM he's able to open Insight too.
If the User isn't Logged into CPPM and tries to Log into CP Insight he gets Rejected on the Login Web Interface. He's saying Wrong User/Password. Which is definitly wrong. If I look at the Access Tracker my Request is successfully authenticated.
My Question is. How should the Enforcement Profile look ? I've set up an Application Enforcement -> User Role - Operator Login Admin User.
I Guess, I should set a specific Attribute for Authentication. I searched already but didn't found anything.
With Local Users, everything work's fine but how to set the Access Attributes for an Active Directory user and which one ?
Thx in advance
P.S.
Main Reason is to open the Links in the Email from Insight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Aruba Insight Management Login
05-20-2017 12:49 AM
I would copy the "[Insight Operator Logins]" service, add your AD to the authentication tab then alter the enforcement to allow access from your AD authentication source.
Cheers
James
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-21-2017 08:29 PM
You need to add Active Directory as Authorization source. If you have already added it then please share your service snap including authentication, authorztion, enforcement policy and access tracker logs.
Milind Yashwantrao
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
06-28-2017 06:32 PM
Seems like there is slightly more required than just adding AD as an Authentication or Authorization source...
Has anyone got this working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
06-29-2017 02:15 AM
What service type you are using to authenticate insight user againt AD?
We need to use Inisght Operator login service. In
Pavan
If my post address your queries, give kudos and accept as solution!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
06-29-2017 01:14 PM
Thanks Pavan,
I tried this and it looked like it should have been working OK.
Could you share screenshots of a working example?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
