Contributor I
Aruba VIA and lollipop problem
We have VPN VIA users and they cannot connect android 5.x versions. Is there any known issues? Aruba and Android is not like themselves, I think :)
The last thing I can see from logs is
May 14 12:01:59 isakmpd[1905]: <103101> <INFO> |ike| IPSEC SA deleted for peer 1010.210.50
May 14 12:02:04 isakmpd[1905]: <103102> <INFO> |ike| IKE SA deleted for peer 10.10.210.50
show version
ArubaOS (MODEL: Aruba6000), Version 6.4.2.4
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-01-15 at 18:50:32 PST (build 48122) by p4build
ROM: System Bootstrap, Version CPBoot 1.2.0.0 (build 20527)
Built: 2009-01-20 18:56:10
Built by: p4build@re_client_20527
Switch uptime is 2 hours 4 minutes 38 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:50)
Supervisor Card
Processor XLR 732 (revision C4) with 1979M bytes of memory.
32K bytes of non-volatile configuration memory.
512M bytes of Supervisor Card System flash (model=CF 512MB).
Thanks a lot;
Re: Aruba VIA and lollipop problem
Problem also occurs with ArubaOS 6.4.2.6 version.
I suggest opening a TAC case
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
We learned our problem. We have struggled because we entered the same ip for the inner and outer ip in via profile. When we changed the inner ip the problem solved. The latest Via version (2.2.8) works with Android 5.1, even with 5.1.1 versions well.
