Aruba controller not redirecting to CPPM
i just replaced a 3600 Controller with a 7030 becaue I needed to add more APs than the 3600 would support.
I have everything else up and running, but for some reason I can't get the controller to redirect to my CPPM server for guest authentication.  I changed the Login Page on the under the CP profile to the Weblogin configured on the CPPM, but whenever I test the Captive Portal, even from the controller, it tries to go here:
https://10.254.254.236/cgi-bin/login?profile=Clearpass-Versatile-Guest
rather than here:
https://clearpass.versacomm.com/guest/Versatile_Guest_Network.php?
which is where it is supposed to go.
10.254.254.236 is the controller's IP address and Clearpass-Versatile-Guest is the name of the CP profile on the controller.  The Clearpass is at 192.168.10.145 and it still works from the old 3600.  I have to be missing something simple, but I can't for the life of me figure out what it is.
Re: Aruba controller not redirecting to CPPM
Is the captive portal profile selected in your guest logon role?
Sent from Nine
Tim Cappalli | Aruba Security
Can you share the ACLs under CAPTIVE-PORTAL-ROLE (INITIAL ROLE)
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Here are the initial Role and the ACLs associated:
user-role ClearPass-Guest-Login
 captive-portal "Clearpass-Versatile-Guest"
 dpi disable
 web-cc disable
 access-list session global-sacl
 access-list session apprf-ClearPass-Guest-Login-sacl
 access-list session Clearpass-Guest-Weblogin
 access-list session logon-control
 access-list session captiveportal
ip access-list session captiveportal
captiveportal
Priority  Source  Destination  Service          Application  Action        TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
1         user    controller   svc-https                     dst-nat 8081                           Low                                                           4
2         user    any          svc-http                      dst-nat 8080                           Low                                                           4
3         user    any          svc-https                     dst-nat 8081                           Low                                                           4
4         user    any          svc-http-proxy1               dst-nat 8088                           Low                                                           4
5         user    any          svc-http-proxy2               dst-nat 8088                           Low                                                           4
6         user    any          svc-http-proxy3               dst-nat 8088                           Low                                                           4
ip access-list session logon-control
logon-control
1         user    any                      udp 68                 deny                             Low                                                           4
2         any     any                      svc-icmp               permit                           Low                                                           4
3         any     any                      svc-dns                permit                           Low                                                           4
4         any     any                      svc-dhcp               permit                           Low                                                           4
5         any     any                      svc-natt               permit                           Low                                                           4
6         any     169.254.0.0 255.255.0.0  any                    deny                             Low                                                           4
7         any     240.0.0.0 240.0.0.0      any                    deny                             Low                                                           4
ip access-list session Clearpass-Guest-Weblogin
1         user    ClearPass_Server  svc-http                permit                           Low                                                           4
2         user    ClearPass_Server  svc-https               permit                           Low                                                           4
The 2 addtional ACLs at the top (global-sacl and the AppRF acl_ have no rules inthe them but I get an error when I try to delete them from the role.
- Make sure that if you are using ClearPass VIP in your Guest URL that IP address is included in your ClearPass_Server netdestination
- Also verify that the https://clearpass.versacomm.com/guest/Versatile_Guest_Network.php URL is configured as your Login Page
- From the Guest network can you reach the clearpass.versacomm.com ?
Thank you
Victor Fabian
You can't delete those .
Those are use for AppRF rules
Thank you
Victor Fabian
I checked and the the netdestination is set to 192.168.10.145 which is the Clearpass server and the URL is correct.
When I connected to the guest network, I can ping the controller but I cannot ping the clearpass server by either name or IP.
Do you have an IP address assigned to the Guest VLAN in the controller ?
How do you have your guest network configured?
- Routable in your internal network
- Only internal to your controller
- Or going through your DMZ
Thank you
Victor Fabian
The Guest network VLAN does have an address on it, but it's not associated to a physical port or port channel on the controller.
