ArubaOS Built In Certificate renew
hi,
my Aruba Controller Built-in Certificate has expired in 11 auguest 2017, could any one tell me to witch version i should upgrade my controller to get a valid certifcate.
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: ArubaOS Built In Certificate renew
You should not be using the default certificate. You need to acquire your own
Tim Cappalli | Aruba Security
Hi Cappali,
thank you for the answer , i know that i do not have to use it, i need to use it , because my customer can't bay a public certificate.
so could you tell to witch version I need to upgrade my Controller to get it, or not ?
Regards
Raouf CHAHBOUNE
You cannot use the default certificate in a production environment.
Hi Cappali,
I should not and i know the risks, now if you now a version of arubaos that it have a valid certificate tell me .
and any way thanks for your advices.
Raouf CHAHBOUNE
There is no valid certificate. They're self-signed and cannot be used.
I'm talking about the built in certificate , i use to work with it  but it have expired in 11/08/2017.
for the seconde time i know that i should not use a buit in , but  i need to use it.
Raouf CHAHBOUNE
It was revoked last year. You need to provide your own certificate.
cappalli
i read your article
https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
do you have any tutorial to generate a cerificate with lets encrypt
Raouf CHAHBOUNE
No. LetsEncrypt is not recommended as it requires a renewal every 90 days. You can get a standard certificate for around $4.99.
