ArubaOS Internal DB is not working
  • 1.  ArubaOS Internal DB is not working
    Posted May 08, 2014 06:30 AM
    I have a problem with an Aruba 650 Controller running ArubaOS 6.4.0.3.
    I configured Campus WLAN for guest access and want to use the Internal DB of the Controller. So far, everything okay. The Guest-WLAN work correctly, guest-logon role redirect to the Captive Portal.
    NOW MY Problem:
    In the Web-UI i can not enter the Internal DB of the Controller. (SECURITY -> Authentication -> Servers -> Internal DB)
    When clicking on the + next to Internal DB nothing happen. I can not click on Internal DB, too.
    To test an other way it created a Guest Provisioning Account. I can log in with the Provisioning Account, but when trying to create a new user, the user won't be listed after clicking on "CREATE" in the little POP-UP window.
    Without Access to the internal DB of the Controller, I can't authenticate any guest users.
    Please Help! I have no clue where the problem is.
    Thomas
  • 2.  RE: ArubaOS Internal DB is not working
    Posted May 08, 2014 06:57 AM
    Have you tried another browser or using the CLI
  • 3.  RE: ArubaOS Internal DB is not working
    Posted May 08, 2014 07:30 AM
    Hey,
    its not working with any browser:
    Internet Explorer
    Chrome
    Firefox
    How can I enter from CLI to manual add users to the Internal DB?
    It's not the solution the costumer want to have for their receptionist, but maybe a fist attempt to find the problem.
    Thomas
  • 4.  RE: ArubaOS Internal DB is not working
    Posted May 08, 2014 07:50 AM
    Hey,
    i tried to add a user manually..
    that was the error message:
    Error accessing the Local User DataBase. Run "local-userdb fix-database" to fix the Local Database. Caution: fix-database command will drop the database and create a new one.Try to export the Local Database("local-userdb export <filename>") in case you want to save the existing data.
    BUT:
    i can not execute the local-userdb fix-databae command!
    that is the error-message:
    Controller#local-userdb fix-database
    % Invalid input detected at '^' marker.
  • 5.  RE: ArubaOS Internal DB is not working
    Posted May 08, 2014 07:55 AM
    trnordmann,
    Do you have a master/local setup (more than one controller)?  I would try to add the user on the master controller, if you can.
  • 6.  RE: ArubaOS Internal DB is not working
    Posted May 09, 2014 02:53 AM
    Hey guys,
    @cjoseph: it is just a single 650 Controller, small environment
    thanks for your help! I could solve the problem..
    I saved the running-configuration and then WRITE ERASE ALL the controller.
    After that I replaced the old licenses and copied the saved configuration back on the controller.
    After that complete erase of the controller i could access the Internal DB again!
    Thomas
