ArubaWificfg issues
I try to configure Arubawificfg to connect to our wireless network on win7, i tried many configurations without success...
When i use this one : ArubaWifiCfg_Vista.exe -add /SSID:CLG /Authentication:WPA2 /Encryption:AES /EAPType:PEAP /InnerAuthentication:MSCHAPv2 /UseWindowsLogonInfo:FALSE i need to activate the IEEE8021x manually if i want to enter my authentication parameters.
If i add these parameters  /KeyProvidedAutomatically:TRUE /IEEE8021xEnabled:TRUE , i have an invalid input error ....
When i'm using that one on XP, it's working well !!!
ArubaWifiCfg_XP.exe -add /SSID:CLG /Authentication:WPA2 /Encryption:AES /KeyProvidedAutomatically:TRUE
/IEEE8021xEnabled:TRUE /EAPType:PEAP /InnerAuthentication:MSCHAPv2 /ValidateServerCert:TRUE,
Anyone have an idea to help me ?
Thank's
Pascal,
Re: ArubaWificfg issues
Hi Pascal,
ArubaWifiCfg application for Windows XP uses different parameters than Windows Vista (Windows 7) version.
/KeyProvidedAutomatically:TRUE does not exist in Windows Vista (Windows 7) version as this relates to a deprecated function for dynamic WEP key.
Valid syntax for ArubaWifiCfg for Vista is the following:
SYNOPSIS:
ArubaWifiCfg [-add | -delete | -help] /SSID:[SSID] ... ...
DESCRIPTION:
/SSID:[SSID] Wireless Network name [1-32 characters]
/Authentication:[ open | shared | WPA | WPAPSK | WPA2 | WPA2PSK ] Authentication method
/Encryption:[ WEP | none | AES | TKIP ] Encryption type
/NetworkKey:[ NetworkKey ] Network key
/KeyIndex:[ 1 | 2 | 3 | 4 ] Key index
/EAPType:[ PEAP | EAP-TLS ] EAP method
/InnerAuthentication:[ GTC | MSCHAPv2 ] Inner authentication method
/UseWindowsLogonInfo:[ TRUE | FALSE ] Use Windows logon info
/EnableFastReconnect:[ TRUE | FALSE ] Enable fast reconnect
/ValidateServerCert:[ TRUE | FALSE ] Validate server certificate
/TrustRootCA:[ TrustedRootCA ] Trusted Root Certification Authorities
/DebugLog:[ TRUE | FALSE ] Log file generated
In you specific connection scenarion, you should use the following:
P:\Applications\Aruba>ArubaWifiCfg_Vista -add /SSID:CLG /Authentication:WPA2 /Encryption:AES /EAPType:PEAP /InnerAuthentication:MSCHAPv2 /UseWindowsLogonInfo:FALSE /EnableFastReconnect:TRUE /ValidateServerCert:TRUE
Paul Gallant, Eng.
CWNA, CWSP
Thank's Paul for your answer BUT ...
The only way i can connect to the wifi it's to activate the IEEE802.1x, otherwise, i can't enter my login information !!!!
Why i can't use this syntax?
/IEEE8021xEnabled:TRUE ????
Merci.
Hi Pascal,
You are right, using the Windows Vista tool, the profile Wireless LAN Profile is not created with the 802.1X enabled.
I guess in the short term, you can document this as the students will certainly appreciate being able to store their credentials to avoid re-entering them each time.
Paul Gallant, Eng.
CWNA, CWSP
