Contributor II
Assign more than one Tagged VLAN on a Switch Port
Hi all,
I was just running in a problem, but so far I'm not sure if it is a bug in ClearPass, a configuration error or a limitation.
What I try to achieve:
I have an HPE AP which is configured for local bridging. So so static portconfig looks like: VL7 (untagged / management), VL 10-12 (tagged /SSID traffic)
Now I want to assign all VLANs dynamically. So on Clearpass I created one Enforcement Profile per VLAN and bound them on my Enforcement Policy. After successfully authenticating my AP the switchport only gets two VLAN IDs assigned: VL7 untagged and VL10 tagged. The other two VLANs are missing.
In the AccessTracker output I can see that only the two VLANs are forwarded to the switch.
As I read the RFC on the FreeRadius page (http://wiki.freeradius.org/vendor/HP#procurve-port-authentication-special-features_dynamic-vlan-assignment_rfc-4675-multiple-tagged-untagged-vlan-assignment) the egress-VLANID attribut can assigned more than one time.
"Times used = 1-*"
Can anyone help me on this beahvior?
thanks i advance folks!
Network Engineer
ACCX | ACMP
Re: Assign more than one Tagged VLAN on a Switch Port
Not sure how you configured it, however when I try, I see the native VLAN and the tagged vlans assigned:
hp2530# show port-access clients 3 detailed
 Port Access Client Status Detail
  Client Base Details :
   Port            : 3                     Authentication Type : mac-based
   Client Status   : authenticated         Session Time        : 90 seconds
   Client Name     : 94b40fcd0832          Session Timeout     : 10800 seconds
   MAC Address     : 94b40f-cd0832
   IP              : n/a
  Access Policy Details :
   COS Map         : Not Defined           In Limit Kbps       : Not Set
   Untagged VLAN   : 2
   Tagged VLANs    : 32, 34
   Port Mode       : 1000FDx
   RADIUS ACL List : No Radius ACL List
hp2530# show version
Image stamp:    /ws/swbuildm/rel_spokane_qt_qaoff/code/build/lakes(swbuildm_rel_spokane_qt_qaoff_rel_spokane_qt)
                Aug 11 2016 15:32:10
                YA.16.02.0010
And this is how my response shows in Access Tracker:2016-11-22 16_40_03-ClearPass Policy Manager - Aruba Networks.png
What I did do, and might be a difference is that I have a single enforcement profile for the tagged ports, HP-Tagged-VLANs with the two VLANs in my lab inside. So two profiles in total.
Related posts:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Egress-VLANID/m-p/76850
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Assign-Tagged-VLAN-via-Radius-attribute-using-quot-HP-Egress/m-p/260167
Contributor II
hi Herman,
thansk for the hint! I have successfully tested it and it works.
Network Engineer
ACCX | ACMP
