Auth-survivability issue
Hi
I have enabled auth-survivability on your controllers. I can see in that the controller is caching EAP-TLS clients but nor EAP-PEAP clients. It's the same on 72xx and 70xx controllers. Prevoius software versions did cache EAP-PEAP clients. Is this a bug ?
Guest users are cached as well.
Running ArubaOS: 6.5.0.4
Auth-survivability is set to 24 hours.
BR
Bjørn Vollelv
Re: Auth-survivability issue
That's the correct behavior
https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/2450
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks for your replay.
If I have understood you correctly is that EAP-PEAP is not supported anymore. This was working in earlier versions.
Please open a TAC case.
Tim Cappalli | Aruba Security
Moderator
I'm pretty sure EAP-TLS & EAP-PEAP used to be supported on the MAS switches were you thinking of this perhaps?
Best Regards
-d
ClearPass Product Manager
I was thinking that it was supported on the controllers.
