Frequent Contributor I
Authenticate admin network of cppm by a external RADIUS.
Actually it is not possible to authenticate the admin networks of Clearpass by an external TACACS serveur.
But my client wants to centralize admin authentication on his ACS server.
Is it possible to use an exetrnal RADIUS server (i.e : ACS) for authenticate the admin networks of Clearpass ?
I try to do it after have add :
  • First add authentification source RADIUS
  • Second add RADIUS Generic service
Unfortunately, that doesn't work... probably bound to service rule ..
Have you an idea ?
Regards
Yann
Trusted Contributor I
Re: Authenticate admin network of cppm by a external RADIUS.
it seems that way, but perhaps someone else has a direct solution.
my approach would be to use the default service for CPPM access: [Policy Manager Admin Network Login Service] at authentication you can add a RADIUS server as source, just use the ACS there.
also, you probably already suggested this, why not replace the ACS with ClearPass?
