Frequent Contributor I
Authentication with UPN
Employees are currently connecting to the company wireless with their SAM account name.. we are in the midst of changing all authentication to UPN account name.  Is there a way (in Clearpass) for authentication to use SAM and UPN?  eventually it will just be UPN but for the migration, both will be needed.
Re: Authentication with UPN
Both are valid, you just need to use the strip rule to remove it prior to authentication:
Tim Cappalli | Aruba Security
so all I have to do is enable 'Strip Username Rules' and enter "user:@,\:user"
Yes. When that is enabled, all of the following will work:
username
username@domain.com
DOMAIN\username
HOST\computer-name.domain.com
The nice thing with UPNs is you can make policy decisions based on the authenticating user's domain. This is how eduroam works at its core. You can either do seperate services for each domain or just reference the "Authentication:Full-Username" attribute in a role map or enforcement policy.
didnt work.. do I need to configure something else?
What is ClearPass showing on the alerts tab in access tracker?
Error Code:
216
Error Category:
Authentication failure
Error Message:
User authentication failed
 Alerts for this Request
RADIUSServer - xxx.xxx.xxx.xxx: User not found.
MSCHAP: Authentication failed
EAP-MSCHAPv2: User authentication failure
OK. You'll need to modify the authentication filter to be:
(|(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))(&(objectClass=user)(userPrincipalName=%{Authentication:Full-Username})))
Access tracker now says: Search failed due to bad filter
Hm. OK. Try this one:
(|(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))(&(objectClass=user)(userPrincipalName=%{Authentication:Username})))
