Auto Sign-On with ClearPass and ADFS
Hello everyone,
A custumer wants to do ASO with ClearPass and ADFS.
Example : a employee goes to a captive portal and logs in. Then, when he goes to an web application ASO compatible (SharePoint for example), he's automatically logged in.
I read the technote about SAML Configuration, but i'm not sure to understand how it works. I've never worked on that.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=24992
If i'm right, ClearPass would be the Service Provider (SP) and ADFS would be the Identity Provider (IdP).  After a succesful 802.1X authentication, un token is generated by ClearPass and sent to the controller.
When the user goes to the application, he is redirected to the IdP URL to do a SAML request. The controller intercepts the request and inserts the token and forward it to the SAML IdP.
Then the IdP checks the token. If it's valid, it sends a SAML assertion in the response to the user.
My question is : how the IdP can check the validity of the token ?
Thank you for your help
Re: Auto Sign-On with ClearPass and ADFS
For ASO, ClearPass is both the IdP and SP and you’d need to use SAML chaining to use a secondary IdP.
Tim Cappalli | Aruba Security
Thank's for your quick reply !
Is there any documentation which can help to understand how to implement it ?
Unfortunately we don’t have documentation for every identity provider. There are too many of them.
Hi Tim,
I'm interested in this subject too.
Can you just explain the SAML chaining part?
The idea would be to chain authentication request from Clearpass to ADFS? would it be done through a service?
I found your doc on Cloud Identity providers, would it be the same kind of process?
