Super Contributor II
Auto detecting Amazon Echo devices
Clearpass thinks the Amazon Echo I've connected to the network is a Kindle. Now I can fix this manually but its a real pain if you;re trying to reastrict the types of device conecting to the psk network and expecting an end user to connect their device.
I've enabled IF-MAP on the mobility controller and its generating a User Agent string of the form shown below. Any way this is an Amazon Echo unique string ?
Dalvik/2.1.0 (Linux; U; Android 5.1.1; AEORD Build/LVY48F)
Re: Auto detecting Amazon Echo devices
o.k. the clearpass definition of an Amazon Echo doesn;t have OUI 4cefco as one of the valid strings to identify an echo
AEORD is the model number
Tim Cappalli | Aruba Security
o.k. so how would I take the existing fingerprint for an Amazon Echo and
a). add an extra OUI as per the device I've got
b). add a check for a uer agent string containing AEORD
You don't. You'd use it role mapping.
o.k. thats the user agent string as per the example you had for legacy devices. ok makes sense.
Is there an XML  schema for a device fingerprint we can use a template for creating our own custom fingerprints ?
No, there's not.
more to the point, if you create a custom fingerproint.... and its wrong, how do you delete a custom fingerprint?
o.k. found how to delete a fingerpring ...but
Got an echo that has the following setup as shown by access tracker
I then created a custom fingerprint using
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
<TipsHeader exportTime="Tue Jul 24 12:38:04 BST 2018" version="6.7"/>
<DeviceFingerprints>
<DeviceFingerprint category="Home Audio/Video Equipment" family="Amazon" name="UoY Amazon Echo">
<FingerprintRules>
<FingerprintRule match-conditions="ALL">
<RuleCondition name="mac_vendor" operator="contains" value="Amazon"/>
<RuleCondition name="dhcp.option55" operator="contains">
<valueList>1,33,3,6,15,28,51,58,59</valueList>
</RuleCondition>
<RuleCondition name="dhcp.option60" operator="contains">
<valueList>dhcpcd-5.5.6</valueList>
</RuleCondition>
<RuleCondition name="dhcp.options" operator="contains">
<valueList>53,50,57,60,12,55</valueList>
</RuleCondition>
<RuleCondition name="mac" operator="contains">
<valueList>34d270,40b4cd,fca667,8871e5,4cefc0</valueList>
</RuleCondition>
</FingerprintRule>
</FingerprintRules>
</DeviceFingerprint>
</DeviceFingerprints>
</TipsContents>
Deleted the endpoint entry and rebooted the Echo..... and it still comes back as a Kindle, so why doesn't my custom fingerprint kick in first?
A
MAC VendorAmazon Technologies Inc.
Added byPolicy Manager
StatusKnown
Device CategorySmartDevice
Device OS FamilyAndroid
Device NameKindle
MAC Address4cefc0ae4bb6
IP Address10.241.88.152
Static IPfalse
Hostnameamazon-488bf99be
Profile Conflictfalse
Added DateJul 24, 2018 15:32:59 BST
Updated DateJul 24, 2018 15:32:59 BST
Fingerprint Details -
DHCP Option60["dhcpcd-5.5.6"]
DHCP Options["53,50,57,60,12,55"]
DHCP Option55
["1,33,3,6,15,28,51,58,59"]
Gwtting closer..... If I just have
<FingerprintRules>
</RuleCondition>
</RuleCondition>
</RuleCondition>
<valueList>4cefc0</valueList>
</RuleCondition>
</FingerprintRule>
</FingerprintRules>
and only specify 1 OUI then it works! How do I specify multiple OUIs and mean if one of these exisits ....
