Frequent Contributor I
Auto-generated anonymous account for web login
How do I create another auto-generated anonymous account in ClearPass?
Earlier this year, a support tech helped me create a login page that just required the clients to click a check box.  It used a hard coded login.  I am trying to create another similar page, and need a new login, but when I go to create the account in ClearPass, it will not create all the "variables" needed for the Web Page to work.
The login the tech created has "Auto-generated anonymous account for web login:" in the description.
Jason...
Re: Auto-generated anonymous account for web login
Inside the web-login itself, it will ask you if you want to create one when
you select Auto-generated anonymous from the drop down.
Tim Cappalli | Aruba Security
Much thanks.  That is what I was missing.   I was trying to manually create the account and was running into several problems.
Thanks, again.
Jason...
