How do I send a successful authentiction (specfically a vsa) from the new version of cppm (guest)?
I am finding the integration between the two products confusing, due to my lack of familairity
I have used a template and I have got the captive portal set up and get the splash page and authenticate, but in accesstracker I see no output from the authentiction attempt, except an enforcement profile (which is positive), also a little concerned the controller's nas id is not in the packet, so if it sends back a vsa I guess the role change may not go into effect.
has anyone come across similair situation?
thanks
