Best practice for installing Aruba 7200 controller.
I've done the basic iAP225 with Virtual Controller configuration and installation and it appears to be working ok. This was my first try at the Aruba product and pretty much a trial run for me to see if my university would go any further. My supervior has informed me that we have purchased two 7220s and several more iAP225s. Looks like we are going further!!!
I am basically starting from scratch with this so my options here are fairly open but I do want to make sure that everything is done properly and correctly. I have read several 7220 and Aruba OS documents so I do have the basics down.
Is there a "best practice" document for setting up an Aruba wireless network with two 7220 controllers?
Thanks.
Re: Best practice for installing Aruba 7200 controller.
Hi Victor, about this i have a doubt. I customer wants to purchase a 7200 controller and connected to switches from gig interfaces of the controller instead the ten gig interfaces. I would like to know if this is an valid option or what consequences could bring ?
