Best practice for multi-use ports and VLAN's
I am sure this has been done before and is possible but I am unsure of what is the best way to configure it or where I can get the configure. The scenario is for wired ports on a edge switch, user with windows laptops have 802.1x through GPO, while Phones and Printers can be used on the ports.
I want to configure all ports the same so IMAC doesn't require port configs
When a phone is plugged in, it will fail 802.1x but be in the Clearpass MAB and the VLAN changed phone VLAN X tagged and untagged Data VLAN Y
When a printer is plugged in, it will fail 802.1x and MAB list will send Printer VLAN Z
When a laptop is plugged in, it will pass 802.1x and VLAN A Corp Network assigned.
How would i best configure this, configure the port for the phone, and on clearpass enforcement policy assign a VLAN for the printer and Corp?
Re: Best practice for multi-use ports and VLAN's
Did you read the ClearPass Solution Guide for Wired Policy Enforcement? Colorless ports are covered in great detail.
Tim Cappalli | Aruba Security
Thanks Tim,
I hadn't but I will
