Best way to have Onguard check for TOR
We are running Clearpass Policy Manager 6.6.3 and using Onguard to check for encryption and AV. How would I go about checking if a device has TOR installed?
Via Peer to Peer checks? Processes?
thanks !
Re: Best way to have Onguard check for TOR
As far as I understand it, the Tor browser presents to the OS as Firefox which may make it difficult to enforce.
Tim Cappalli | Aruba Security
is there any way to check TOR application from clear pass onguard
