SBS
Contributor II
Block pokemon go
Has anyone setup their controller to block Pokémon Go?
I looked up the aruba defined apps and don't yet see it in the listing so is there another way at this point?
Thank you
Re: Block pokemon go
Pokemon Go is too new to be identified. We can ask, however.
The big question is, do you suspect that Pokemon Go consuming alot of your bandwidth? Users can just use cellular data to play if you block it...
Colin Joseph
Aruba Customer Engineering
SBS
Contributor II
Thanks for the reply and for asking about it to be identified by Aruba.  Our school administrators are worried that kids will play the game @ school and want us to make sure it's block it on the school wifi.   So I wanted to check to see how/if we could do that to be able to answer them back :-)
Thank you!
Sarah
Frequent Contributor I
As stated, blocking anything on your network isn't going to do too much because most of the students will just turn on their cellular data and bypass your network.
But if you block the following URL through your firewall/content filter it should prevent network access to the game:
pgorelease.nianticlabs.com
SBS
Contributor II
Thanks for the URL info.
Occasional Contributor I
In my case, to start with, it would be good to know how many people are playing and where.  Any ideas on making that kind of report?
-Andy
SBS
Contributor II
School is out for Summer. The administration wants to be proactive with making sure it's blocked on our school wifi (we realize if they are using cellular we can't control), but want to make sure it's blocked on the aruba wifi before students come back to school next month.
Maybe if they are lucky enough, the school's big concrete walls will block LTE signal :)
ACMP, ACCP, BCNE
Try this:
netdestination pokemon-go
    name pgorelease.nianticlabs.com
ip access-list session deny_pokemon-go
    user alias pokemon-go any deny
Add the session ACL to your user-role(s) and be sure your controller has DNS servers defined and name lookups enabled.
Tim Cappalli | Aruba Security
SBS
Contributor II
Thank you
