Regular Contributor I
CISCO and ClearPass "could not determine role id for user clearpass"
i have implemented a CleraPass (with guest self-provisioning) with a CISCO WLC.
I used the integration guide of CISCO WLC and Amigopod.
I have created the service like if the controiller was an aruba controller.
The only difference is that instead Aruba:ESSID-Name i have use Connection: SSID.
When the guest try to connect to SSID him is redirected to Captive Portal, he put the required information but when click on "Register" he receive this error:
I have try to manually create a guest user, so he is able to login.
do you have any idea?
Thanks in advance.
Best regards
Andrea
Andrea
Aruba
Re: CISCO and ClearPass "could not determine role id for user clearpass"
Packet-capture on Clear pass server can tell you what radius attribute coming in to server especially on radius-access request.
Clear pass may drop and not return if we dont see the attribute config.
I have tried to remake the guese self registration page and now all works fine.
Best regards
Andrea
Andrea
