Frequent Contributor I
CORP SSID redirect for cert carrying/onboarded devices when attempt to associate to GUEST SSID
As per subject,
If a device is carrying organisation certificate or CPPM OnBoard certificate and attempt to associate to a GUEST SSID (where security is less, say on Internet traffic, not behind organisation content filter, etc) can one force them to associate to CORP SSID ?
Re: CORP SSID redirect for cert carrying/onboarded devices when attempt to associate to GUEST SSID
No. when a device connects to an open SSID they do not present the cert so CPPM would not know if it is a onboard cert, BUT you can add an attribute to the device when its onboarded and when they connect to the guest SSID (Mac Auth) then you can force them to a captive portal stating they are connected to the wrong SSID.
Tim did a great how to a few years ago that is still relevant.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Guide-Using-ClearPass-to-steer-users-to-secure-networks-mhc/m-p/144823
Thank You,
Troy
Brilliant.. exactly what i'm after.  Thankyou.
