Re: CP API reference documentation
The Doc are all on the server also
Go to the following page and the WSDL is there and if you click the help on the top there is more detailed information.
Thank You,
Troy
Yep, that information is present in the attached links and also the User Guides.
Apart from aquisition, is there any reason why there are at least 3 different types of API?
