CP Guest Redirection not happening automatically
Dears,
1)I have created weblogin page in CP Guest. (Registerpage: https://192.168.1.3/guest/arubalogin.php)
Conf below11
22
33
44
55
66
2)then I created a service in CP with simple allow access policy. with authentication set to guest user repositary.
1122
Then Created an SSID with following config in wizard.
SSID Name: guestP-T
Forwarding Mode: tunnel
Radio Type:All
Broadcast SSID: Yes
Vlan: 10 (192.168.1.0/24)
Internal/Guest: Guest
Auth... and Encr...:  Captive Portal with Auth. via credentials (Username& Password) provided by user
Captive portal: Enabled
Authentication server: (External)192.168.1.3
Role Assi...: Pre-auth Role: guestP-T-guest-logon
                     Authenticated Role: Guest
Finish.
4)Under Configuration- Authentication- L3 Authentication-Captive Portal Authentication-guestP-T-cp_prof
edited login page to: https://192.168.1.3/guest/arubalogin.php
apply and save conf.
Now when i connect to this SSID and try to browse to 1.1.2.3 (Any IP)
I am not getting redirected to login page.
But when i enter "https://192.168.1.3/guest/arubalogin.php" Manually, things run fine.
Please help to figureout the issue.
Re: CP Guest Redirection not happening automatically
1) Why are you using an IP address instead of an FQDN? ClearPass should only be accessed via FQDN
2) Does your controller have an IP address in the client subnet?
Tim Cappalli | Aruba Security
