Or rather, CPPM doesn't recognize the WEBAUTH request from Guest...
I’ve used the Policy Manager “service templates” to make a pre-auth service for the webauth from Guest, and the actual auth requests from Guest don’t match the service profile, so they’re getting denied.
Some advice on getting the Guest requests to match the webauth service (both built-in or wizard generated, so I’d expect them to work)
for the intrepid reader, here's the log of the reuqest:
Request log details for session: W00000006-01-531a3038
Time Message
2014-03-07 13:46:48,679 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] ERROR com.avenda.tips.dhcp.snooper.request.MacLookupRequestHandler - No MAC address exists for ip 10.10.6.31
2014-03-07 13:46:48,679 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] INFO com.avenda.tips.webauthservice.reqhandlers.RequestUtils - Failed to get macAddress from dhcpSnooper, reason=No MAC address found
2014-03-07 13:46:48,679 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] WARN com.avenda.tips.webauthservice.NadProvider - Cannot find NAD IP since client MAC is not known
2014-03-07 13:46:49,593 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915527 h=79 r=W00000006-01-531a3038] ERROR Core.ServiceReqHandler - doServiceClassification: Error. Ret code=0 response list size=0
2014-03-07 13:46:49,596 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] ERROR com.avenda.tips.webauthservice.WebAuthHandler - Failed to perform webauth, reason=FailedToClassifyRequestToService
2014-03-07 13:46:49,601 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] WARN Common.MacAddrAttrProvider - HostMac missing, not populating different mac representations
2014-03-07 13:46:49,601 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.TagAttrTableUtil - buildTagAttrTableInput: Connection:NAD-IP-Address is not found
2014-03-07 13:46:49,601 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.TagAttrTableUtil - buildTagAttrTableInput: Connection:Client-Mac-Address is not found
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO Common.TagDefinitionCacheTable - No InstanceTagDefCacheMap found for instance id = 0 entity id = 29
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] WARN Common.TagDefinitionCacheTable - Failed to build TagDefinitionMap. Unknown NadClient for Id=0
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.TagAttrHolderBuilder - No tags built for instanceId=0|entity=Device
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.AluTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL AuthLocalUser)
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.GuTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL GuestUser)
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.EndpointTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Endpoint)
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=psauto-1381445979-915528 h=83 r=W00000006-01-531a3038] INFO TAT.OnboardTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Onboard Device User)
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 h=7582725 c=W00000006-01-531a3038] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_OUTPUT_ERROR Started ***
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 h=7582726 c=W00000006-01-531a3038] ERROR Core.PETaskOutputPolicyRes - computeAndOutputResponse: Failed get service config
2014-03-07 13:46:49,602 [RequestHandler-1-0x7f68d6ff7700 r=W00000006-01-531a3038 h=7582725 c=W00000006-01-531a3038] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_OUTPUT_ERROR Completed ***
2014-03-07 13:46:49,604 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] ERROR com.avenda.tips.webauthservice.policy.ChainedPolicyClient - Policy evaluation request failed with statusCode=StatusInvalidParam
2014-03-07 13:46:49,604 [ajp-apr-8009-exec-10] R:W00000006-01-531a3038] ERROR com.avenda.tips.webauthservice.WebAuthHandler - Failed to perform chained policy-evaluation and enfProfiles
