Frequent Contributor II
CPG Self registration with Sponsorship confirmation
Hi all,
I need to validate sponsor against my AD for sponsorship confirmation.
So that I can make sure that the sponsor of the guest is our employee.
Can some one help me to do that.
rana
rana
Re: CPG Self registration with Sponsorship confirmation
Define your LDAP servers in ClearPass guest.
Enable sponsorship in your self registration form (checkbox).
Enable the sponsor look up field in the form.
Tim
Tim Cappalli | Aruba Security
This may help:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Clearpass-Guest-Self-registration-amp-self-sponsorship-email/m-p/191001/highlight/true#M14147
Cheers
James
