Frequent Contributor II
CPPM 6.4 RE-attempt AD login setting
Hi:
The release notes for CPPM 6.4 talk about this:
A new Service parameter, Re-attempt AD login with different Username formats, lets you
control re-tries with different user name formats to the Active Directory in MS CHAP v2
authentication. (#23701)
I couldn't find this. Does anyone know where this option lives in the GUI?
Tony
Re: CPPM 6.4 RE-attempt AD login setting
Server configuration > Service Parameters > Radius server
It's enabled by default.
Tim Cappalli | Aruba Security
Thanks for the reply.
The help file has not been updated with a full description of this option.
But it sure seems like a darned good idea to set this to FALSE to help avoid account lockouts.
Thoughts?
Does anyone know what the different formats are that CPPM will try?
Nevermind!
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-does-ClearPass-perform-MSCHAPV2-authentication-across-AD/ta-p/240056
#1 The username as provided
#2 The samAccountName as returned from the auth source
#3 The full username@domain
