Hello All,
Has anybody had success with SMTP in 6.4.0.66263?
I've tested the SMTP relay I'm using with a couple of other utilities and it works, so I'm pretty sure that's not where the problem lies. In this case/setup, it's not authenticated (no username/password, just port 25 etc.) on the CPPM and test utilities. Nice and simple, all internal traffic.
Having configured the newly build CPPM, and then run a test in "messaging setup", it claims the email was sent. It never arrives. If you look in the event viewer (CPPM), theres an error "email failed", with description claiming "exception reading response". A packet capture of the same, shows the syn-ack returned from the SMTP, followed by a single ACK from CPPM and nothing more.
Any suggestions would be great.
