CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
Hi The publisher and subscriber will be in different locations, and there is L2 link between the two sites. So can I use Eth0 as a cluster probe interface, and Eth1 for data and authentication? Or its better to use only Eth0 for all purposes?
Mahmoud
Re: CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
Please read the following Clearpass clustering guide
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=15546
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Nothing related to interfaces design in this document......
Mahmoud
Re: CPPM Cluster Design if Publisher and Subscrib er in different Locations
Hey, the configuration for each interface is detailed below.
Management Port : The Management port (ethernet 0) provides access for cluster administration and appliance maintenance using the WebUI, CLI, or internal cluster communication. This configuration is mandatory.
Data Port: The Data port (ethernet 1) provides a point of contact for RADIUS, TACACS+, Web authentication, and other dataplane requests. This configuration is optional. If this port is not configured, requests are redirected to the Management port.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
