Regular Contributor I
CPPM Cluster Issue
Guys,
Got 4 cppm nodes - all mgt interfages on the same management DMZ. Two are for DMZ, two for internal auth.
Internal cppm nodes will be used for publisher and backup publisher.
I install certs trusted from the company pki - all OK.  Install PKI roots and intermediates too.
I go to the three remaining nodes and click make subscriber.
Type in IP and PW, and start the sync up.   I get sync error on initial setup.
Policy propagates ok thoughout the cluster, but now I get "Failed to verify server certificate(s)"
From the publisher I cannot view the IPs etc. for the three subscribers.
Constant error at every 30min sync interval, eventual the subscriber drops off.
The subscribers are now using self signed certs too.
Any ideas?
Re: CPPM Cluster Issue
SourceCluster
LevelERROR
CategoryReplication
ActionFailed
TimestampJan 13, 2014 13:00:01 GMT
DescriptionNode with IP=172.29.244.157 out of sync by 31 minutes
Is NTP and timezones set correctly?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
all ok cluster wide I ahve changed the timzone however to it reflects london and not guernsey, I guess in terms of time they are on the time zone - but I can cross that off the list now if you like
thanks for the feedback btw
No joy, contacting TAC
I'll post up the result
Entry in the original VM config backup causing the make subscriber to fail. TAC have reproduced. Incidentally this was a 6.2vm to 6.2appliance import. Got a call this afternoon with TAC for a fix. Serious kudos to TAC ... There should be a kudos button for them in this forum!!!!
Thank you for giving a status update. It helps others if they run into the same issue. :)
Thank You,
Troy
Specifically this was due to endpoint entries in cppm referencing a null vlaue, which within the postgre sql database referenced a tag that had no actual use.  when the subscribers added to the cluster and the database was replayed the clustering failed.  (clearly I cannot take a pinch of credit)
guy on the phone completely nailed the problem and now my cluster is working perfectly... kudos TAC!
