CPPM - Difference between tips database and insight database
Hi guys,
Just that quick question, what is the difference between the tips database and insight database in ClearPass? I have browsed the CPPM user guide and this community and seen no answer.
Julián
Re: CPPM - Difference between tips database and insight database
Insight is the reporting module and that database stores session information.
What are you trying to do?
Tim Cappalli | Aruba Security
Hi Tim,
And tips database? I don't want to do anything, just I am taking the ClearPass Essentials course and in the Guest module they talked about tips and insight database.
Julián
Tips is the configuration database.
You should ask your instructor these questions 😀.
