Contributor I
CPPM Downloadable Roles using VIA client
I'm not sure if this is the correct location for this. I've been working through setting up the VIA client to use as a VPN into our Aruba 7010 controller from off-campus. The last hurdle (and I hope it is just that and not a wall) is trying to setup downloadable roles from CPPM. We use them extensivley on campus but I cannot find the option in the VIA settings. Can someone point me in the right direction?
-Mike
Mike Naylor
The College of Wooster
Re: CPPM Downloadable Roles using VIA client
Unfortunately VIA cannot leverage downloadable roles.
Tim Cappalli | Aruba Security
Contributor I
Can I leverage my CPPM downloadable roles using a different VPN technology?
Mike Naylor
Most other vendors do not use the role concept. You can leverage things like
downloadable ACLs (dACLs) with some vendors.
