CPPM Guest - How to add multi-lang translastions flags to diffrent login page
Hi Guys,
In clearpass,
How to i add to spesefic guest pages the ability to show the flags (and not for all the pages - like the option bellow)
Please advise,
Thanks.
Me
Re: CPPM Guest - How to add multi-lang translastions flags to diffrent login page
I think you'd need to hide the DIV by adding some html to the header of the registration forms.
Tim Cappalli | Aruba Security
Thanks ...BUT:
  • There isnt a built-in feature for that?
  • There isnt an ability to configre to sepsefic guest page to use diffrent multi-lang options?
