Regular Contributor I
CPPM Guest accounts not being deleted
I have a situation where guest accounts are expiring but not being deleted. It is setup with the do_expire field value of 4. Anyone any ideas?
Re: CPPM Guest accounts not being deleted
You also need to set the following parameter under cluster-wide parameters to 1 to have those accounts cleaned up every night:
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
