Super Contributor II
CPPM HPE CoA param missing?
So while I've got CoA working against Comware Switches and fairly certain I had it working against HP Procirve switches  in CPPM 6.5, just tried bouncing a port on a procurve switch in CPPM 6.6. and although it prompts me to bounce port or terminate session, the CoA template expects an IETF Event-Timestamp Attribute which it isn't populating. A CoY request then fails with an "Attribute missing" error message.
Re: CPPM HPE CoA param missing?
What version of code on the switch?
Tim Cappalli | Aruba Security
