Frequent Contributor I
CPPM Mac Caching does not work correctly
Mac Caching with CPPM does not work correctly.
OUr guest users are redirected to a captive portal when they connect for the first time. Generally Clearpass checks if the device is already in de endpoint database, because users should only are forced to login via captive portal once a day.
But in Access Tracker of CPPM I can see that this is not working.
I logged in with a new ipad on my captive portal. Everything is ok. Mac Caching fails as expected.
I disconnected the ipad via the aruba management gui and tried to reconnect.
Then i was prompted to login via captive portal again.
Access tracker shows that mac caching failed. I checked endpoint database and i found the ipad correctly.
Accesstracker shows following Error
Does anybody has an idea about this problem?
Thanks a lot
Aruba
Re: CPPM Mac Caching does not work correctly
Did you creat the two services with the guest Mac auth template? Is insight enabled? You need to post a screen shot of summary.if you answered either one no then you might need to post screen shots of the services and each tab
Thank You,
Troy
Does anyone have an idea?
you didn't answer:
  • Did you create the two services with the guest Mac auth template?
  • Is insight enabled?
  • You need to post a screen shot of summary.
The Services were not created with the template.
Insight is enabled yes.
Screenshots you can find in my postings above
not the screenshot of the summary of the access tracker.
also are these clients in your endpoint repository?
Frequent Contributor II
from your screenshot, your endpoint is in unknown state.
add another enforcement policy in your CP service to do post-authentication action to change the state to known after a succesful CP login.
Ricky.
Ricky E. Lee
CWNA | ACMP | ACCP
Use AllowAll MAC-auth as the authentication method instead of just MAC-auth.
Tim
Tim Cappalli | Aruba Security
