Contributor II
CPPM, Meru WLAN, and Avaya switch integration
I am interested in documentation regarding the integration of ClearPass Policy Manager with Meru wireless and Avaya wired networks.  I am primarily interested in what is supported in terms of Meru and Avaya products, what is not supported, and possibly some guides on how to do it.
I was able to find one document on Aruba's partner portal that discuss some of the limitations of integrating Meru with CPPM: https://afp.arubanetworks.com/afp/index.php/Meru_integration_to_CPPM.  Any VRDs or videos would be good reading.
DAK
