Frequent Contributor II
CPPM Role-Mapping
Hi all,
I'm new in this field.
Can any one explain me how Role mapping works and when it triggers.
rana
Re: CPPM Role-Mapping
Role mapping is optional. It after authentication and before enforcement. The idea is to "tag" the request with as much information as possible and then use that information in the enforcement policy.
Tim
Tim Cappalli | Aruba Security
Thanks it helps.
rana
One more question, If the authentication type is post auth then?
rana
Logically, yes, role mapping happens after authentication. It is part of the authorization "step".
