Occasional Contributor I
CPPM TACACS+ for autnenticating Riverbed Steelhead admins
All,
I'm trying to use CPPM to control admin access to my Riverbed appliances.
I keep getting the following alert in the access tracker: Tacacs service=rbt-exec:unknown not enabled
I have however imported a TACAS service called rbt-exec:unknown in the TACACS+ Services Dictionaries.
I have restarted the TACAS service on both my CPPM's (they are clustered).
I have followed this how-to: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-authenticate-Riverbed-admin-users-against-ClearPass-over/ta-p/192945
All help and suggestions are welcome!
Leo
Re: CPPM TACACS+ for autnenticating Riverbed Steelhead admins
this is fixed now.
Trusted Contributor I
could you explain what you did leo? it might help others with the same question.
I missed one setting on the Riverbeds.
You must set the authorisation policy on the riverbed to remote only. I missed that...
The how-to showed the setting on a screenshot, but did not describe the action to be taken....
Leo
What vendorname do you set for your Riverbed devices?
Has anyone tried this using the "monitor" role (read-only) within Riverbed? This works just fine using the admin role, but suppose someone (me) needed to define read-only access to Riverbed appliances, using CPPM? Haven't gotten this to work ... it only shows the following in my Authorization failure access tracker window:
Regular Contributor II
Please post a screenshot of your enforcement policy in clearpass
