CPPM-WIRED VOIP Phones
Dear All,
Thanks for all the hard work you are doing here.
I ahve a query please-
We have CPPM running on our network for wired and wireless devices.
Recent Telecomms infrastructure refresh dictates that we connect 2500 ip phones on our nerwork piggybacking the network conneciton of the pcs.
We have been told these devices are .1x enabled.
Whats the most decured way of setting these up please -
1. We have .1x on the ports of the switches. Add setting on the port and configure CPPM with radius config to authenticate these ip phones ?
2. IP phones mac address whitelisting ?
What would you do ? Please specify briefly how it should be done.
Sheikh
Re: CPPM-WIRED VOIP Phones
Did you look at the ClearPass Solution Guide for Wired Policy Enforcement?
Tim Cappalli | Aruba Security TME
Hi Cappalli,
Just looking at it now.
Sheikh
