Contributor II
CPPM and Good Tech MDM integration
Guys, can CPPM integrate with Good Technologies MDM? I dont see Good on the Clearpass Mobility Integration guide created by Danny jump in 2014. Has anything changed?
Can they integrate, and more importantly, do you have deployment guide you can provide?
Contributor II
Re: CPPM and Good Tech MDM integration
I've  attached what I think is the latest version of the ClearPass and MDM deployment guide. I still dont see MDM vendor "Good Technology" on it. Anyone know if its supported or not?
Moderator
I just want to come back to this post, we are close to releasing an integration that supports UEM 12.6.x [will also support 12.5 but not QA'd] and I'm looking to see if you still have an interest in CPPM Integration?
Best Regards
-d
ClearPass Product Manager
Contributor II
Becouse Good was not compatible, we took a different route. However, I have a new integration with XenMobile and if you have a VRD for integrating with XenMobile that would help alot?
Thxs
Moderator
So two things.
1. I just posted the Integration Guide between CPPM + BlackBerry UEM 12.6
2. Citrix Xexmobile is just a standard MDM integration. Did you take a look at the MDM TechNote?
Best Regards
-d
Contributor II
This is the only MDM integration info I have. If there is something else please send it over. Thxs
