Contributor II
CPPM and LDAP FreeIPA Integration Erorr
Hi Guys,
I Already Install CPPM and LDAP FreeIPA and i want integrate both with HPE Aruba 2530.
But i got the message like below
Any advice ?
What shoud i do ?
Kindly need your help
Regular Contributor I
Re: CPPM and LDAP FreeIPA Integration Erorr
Did you find the solution for this? I am facing exactly same problem.
Ricky E. Lee
CWNA | ACMP | ACCP
I believe the password should either be stored in Cleartext or Using NThash in the ldap server for mschapv2 authentication to work.
May I recommend you to refer the below blog for freeIAP?
http://firstyear.id.au/blog/html/2016/01/13/FreeRADIUS:_Using_mschapv2_with_freeipa.html
Thank you,
Saravanan Rajagopal
**Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the post.
HI Saravanan,
nice reading and it confirming my issue.
i was thinking it must have something to do with the mschapv2 and i was right.
is there any doc/guide on aruba about successful integration between clearpass and ldap? any ldap beside openIPA would do.
Ricky E. Lee
CWNA | ACMP | ACCP
Following are the guides I could find. Let me know if you need any additional details.
http://www.arubanetworks.com/techdocs/ClearPass/Aruba_CPPMOnlineHelp/Content/CPPM_UserGuide/Auth/AuthSource_GenericLDAP.htm
http://www.arubanetworks.com/techdocs/ClearPass/Aruba_DeployGd_HTML/Content/LDAP%20&%20SQL%20Auth%20Sources/LDAP_Auth_Source.htm
Thank you,
Saravanan Rajagopal
