CPPM integration with HP Wireless Controller
i have an implementation for integration CPPM with HP WLC and HP AP,
so do any one have idea or tech note for this kind of integration.
Re: CPPM integration with HP Wireless Controller
Which model(s) & OS of HP controllers and APs? What type of integration are you looking to set up  (802.1X, MACAUTH, Guest Captive Portal, etc.)?
MVP
I haven't got any experience with HP WLC, but just wanted to make sure you are aware of the following guide. Although I'm not sure if this UWW is the WLC you are talking about.
 http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/ClearPass-and-HP-UWW-dot1x-MAC-Auth-Guest-Captive-Portal/td-p/251320.
Koen (ACMX #351 | ACDX #547 | ACCP)
