Contributor I
CPPM integration with SIEM - HP Arcsight
We have HP Arcsight and want to integrate it CPPM to collect logs.Please help with any solution document or any procedure where I can successfully deploy it.
Trusted Contributor I
Re: CPPM integration with SIEM - HP Arcsight
Contributor I
thanks for the prompt help and support
Moderator
Let me add a little extra info, also the technote posted is only for Logger, below I discuss ESM.....
SInce the acquisition I've been driving the integration (and this will continue over the next few months) for CPPM and ArcSight.
The first action i had to achieve was to get CPPM ArcSight certified. We had previously released CEF syslog format but after working with the arcsight team over at HP we had a few issues related to field-mapping and formatting. As of the next CPPM patch 6.5.4 which we will release this week we have completed all of the changes requested by the arcsight team, so that means we will soon have the CEF Certified Logo - Yippeeeee....
Over the next few months you'll see additional integration features from me as we work closer with the arcsight team.
Best Regards
-d
ClearPass Product Manager
