Contributor II
CPPM public virtual IP
I am installing for a specific client a CPPM server in the cloud with a public IP address. Actually, I would like to configure high availabilty between two.
I have 2 public adresses, one for each server. I have made one the subscriber of the other one and they appear as a cluster of two nodes.
The problem is :
As this cluster is expected to be joined by the client, I would like to configure a virtual IP address for redundancy between the two CPPM.
And because I have two public addresses, i tried to put one of the two public addresses as the virtual IP but it doesn't work.
Also, I don't think the problem would be resolved if I buy another public IP address because CPPM wants all three addresses in the same subnet.
Does anyone have a solution for this ?
Thanks a lot.
Re: CPPM public virtual IP
I'm sorry to tell you the VIP mandates that the three IP@ are in the same subnet, as does other VIP processes HSRP, VRRP etc.
The only solution I know that would work is to front the CPPM's with a SLB/ADC device who's VIP address can be in any IP subnet you wish.
Best Regards
ClearPass Product Manager
Contributor II
Okay, I'll do some research on that.
Thank you.
